3
This discussion topic has been answered Discussion topic: Sky stream
This message was authored by: RWB1
Sky stream
Can I record a program that has already started?
Avatar for RWB1
This message was authored by: RWB1 Answer
Re: Sky stream
Thank you for your replies. I'm not good with technology (I'm an oldie!) but after fiddling around for a while I've worked out how to do it - easy once you know how!
Thanks again for your replies, they pointed me in the right direction.
Re: Sky stream
@RWB1  You should still be able to add it to your playlist while it's in progress.
Re: Sky stream
You can't record on Sky Stream.
You can click the 'watch from the start' button if you want to watch something that's already started right away.
You can add it to a 'playlist' instead which will direct you to all episodes of that programme which are available on demand. Find the episode you want and it will trigger playback via the appropriate third party app or, in the case of Sky channel programming, direct from Sky's servers.
For channels which do not have an on demand app, and for some live sport events, you may get access to a 'cloud recording' or a saved section of the live channel stream, tagged by the EPG metadata at the original broadcast time. This is not a personal recording though and can be removed by Sky at any time, depending on streaming rights for that particular content.
Avatar for RWB1
Re: Sky stream
