Discussion topic: Sky stream
Message posted on 21 Nov 2025 02:57 PM
Sky stream
Message posted on 22 Nov 2025 01:08 PM
Re: Sky stream
Hi Tracy
Try going into Settings and chose System management, then Resets & updates, and select Refresh apps. Just leave it until it automatically returns you to the Home Screen. Try Paramount+ again and see if that sorts it. If not leave it 24 hours as the refresh works behind the scenes for up to 24 hours later. I hope that sorts it.
Message posted on 22 Nov 2025 04:05 PM
Re: Sky stream
I have already tried this but will try again. The app is on tge home screen and working on other devices fingers crossed it works.
Message posted on 22 Nov 2025 04:21 PM - last edited: 22 Nov 2025 04:22 PM
Re: Sky stream
As mentioned above, the refresh apps in Settingscan take up to 24 hours to do a complete refresh of all the apps.
So give it sometime.
Try a settings restart;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
Also, try putting your Sky Stream puck into standby and do a router/hub reboot.
Message posted on 23 Nov 2025 03:43 PM
Paramount +
Paramount + is still a spinning circle. I have updated and refreshed the apps twice in tge past few days and still not working any help?? Or will I have to call Sky support as the bot chat is useless
TIA
