Discussion topic: Sky stream
This message was authored by: Edgar123
Sky stream
My sky doesn't work because there's a tree blocking my dish the engineer came out and said my only option is to get sky stream I don't want the sky glass tv just sky stream so I don't need a dish? Is this possible?? How much does it cost?
Re: Sky stream
@Edgar123
Sky Stream doesn't need a dish but does need fast and stable broadband in order to function. Do you have good broadband with a speed of over 25Mbps?
You do not need to buy a Sky Glass TV, you can just ask for Sky Stream. Sky like to do the hard sell on Glass as it makes them more money but if you already have a TV then you don't need to buy Glass. The Sky Stream puck is a small box which attaches to your TV like Sky Q and streams everything via your broadband.
In terms of cost, it depends on the package you choose and the contract duration. You can find all the information here:
https://www.sky.com/tv/stream
Re: Sky stream
@Edgar123
Research it thoroughly because it's totally different to the methods you're used to via Sky Q.
▪️I AM NOT A SKY EMPLOYEE ▪️
