Discussion topic: Sky stream
This message was authored by: Nancy5
Sky stream
My tv keeps freezing, could it be my sky stream box or dish , I also have broadband?
Re: Sky stream
Sky Stream doesn't use a dish it works via the internet connection.
freezing indicates poor internet connection.
Open Netflix ont he stream puck go to get help, check your network and it will run a speed test. What speed does it report?
if you are connected via WiFi you may find the issue is the strength and stability of the WiFi network. You can improve this by ensuring the position of the puck is out in the open and not in a cupboard or hidden behind anything. Or the router should be positioned correctly to maximise WiFi signal ( it also shouldn't be hidden, shouldn't be on the floor and should be away from things like radiators are other electronic devices that can cause interference).
You could also try disabling the WiFi on the puck and connecting via an Ethernet cable instead.
Re: Sky stream
Do you mean Sky Q mini?
Avatar for Nancy5
Re: Sky stream
Yes sky
This message was authored by: Super+Anthony
Re: Sky stream
There is an issue with the freezing if you with Hyperoptic broadband, which is currently being looked at by hyperoptic
(Please Note: I am Neurodivergent )
This message was authored by: Mister_Dalek
Re: Sky stream
@Nancy5 wrote:
Yes sky
That's a Sky Stream puck, not a Sky Q minibox.
