Discussion topic: Why does sky stream freeze one obe box but is ok on a 2nd box
This message was authored by: dyordlo
I watch one channel for an hour and try change channels but all my boxsays is trying to load program. My second d box is fine - Why
Re: Why does sky stream freeze one obe box but is ok on a 2nd box
If the boxes are connected by wifi ... one box has a good connection the other does not .... check the connection to the internet on each box using the Netflix Network check on each Puck😉
This message was authored by: Dawn1970
Why does my box keep turning itself off and then loads back up and the program I'm watching is almost like it's lip syncing.
