Discussion topic: Sky stream
This message was authored by Dave22z This message was authored by: Dave22z
Sky stream
Hi All
Does anyone  know if it is possible to get a Sky stream puck re activated after a cancelling it after a previous trial period ?
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Re: Sky stream
Hi @Dave22z
Yes it should but you will probably have to call them to do it.
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
This message was authored by bob1234 This message was authored by: bob1234
Re: Sky stream
@Dave22zProbably but you will need to phone Sky, they will have expected the Puck to have been sent back.
This message was authored by SlenderRobert This message was authored by: SlenderRobert
Re: Sky stream
Only if the previous trial was after February 28th (or around that date). All pucks sent out before that are owned by the customer.
Dave22z
Re: Sky stream
Yes the puck was purchased on February 9th and says in my sky customer owned
