This discussion topic has been answered Discussion topic: Sky stream
Message posted on 24 Mar 2026 07:41 PM
Message posted on 25 Mar 2026 03:56 PM
Yes, the speed will fluctuate.
Expect it may do so even more if you have busier times in your household for internet use.
If that is the wifi speed on your Puck, then it should be ok.
But, really even based on Sky minimum speeds for the Sky Stream puck your speeds are around the lower limit to offer the most reliable service for a Sky Stream puck to perform well.
You may have already, but it may be worth looking to see if you can move your broadband to a faster fibre service.
or
As I mentioned above, maybe better for you to try connecting the puck via an ethernet cable to your router or using powerline adapters.
Message posted on 24 Mar 2026 07:52 PM
Re: Sky stream
Hi @BLUEBRUM
What speed is your broadband? Sky stream delivers service via broadband and uses adaptive bit rates.
The aerial port is not active on your sky stream box as is only active in other territories where legally required.
MikeAlanR
Message posted on 25 Mar 2026 12:42 PM
Re: Sky stream
It's 59-66 MB/s my broadband speed, thanks for the reply
Message posted on 25 Mar 2026 12:57 PM
Re: Sky stream
@BLUEBRUM wrote:It's 59-66 MB/s my broadband speed, thanks for the reply
Is that the speed you're supposed to get, or the speed actually measured as being received by the puck?
Run the network check from the get help menu on the Netflix app on the puck (if you haven't already done so) and check it several times to see if the speed is fluctuating. Sky Stream needs as fast and stable a connection as possible.
Message posted on 25 Mar 2026 01:03 PM
Re: Sky stream
If that is the case for you broadband speed estimated or receiving at your router, you may experience issues.
Sky recommended available minimum broadband speed is 25Mbps.
Or 30Mbps if you add an extra Sky Stream puck or watch in UHD.
Just to be certain it's not a speed issue at your puck, can you run the following network speed test on your Puck.
Launch Netflix on your pucks (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test several times, over say a half hour period during tests.
What is the speed for your puck?
If you are running using wifi, you may be better for a lower speed using an ethernet cable or powerline adapters.
If you do use ethernet, make sure you turn wifi off in the Sky Stream puck settings.
Message posted on 25 Mar 2026 03:13 PM
Re: Sky stream
Hi , thanks for the reply, I've done that what you said check the speed on Netflix, connection speed 55.55Mb/s
Message posted on 25 Mar 2026 03:15 PM
Re: Sky stream
Just checked it again now the speed is 49.10 Mb/s
Message posted on 25 Mar 2026 03:19 PM
Re: Sky stream
Now it's 52.38Mb/s
Message posted on 25 Mar 2026 03:22 PM
Re: Sky stream
Now it's 50.08Mb/s it fluctuates that much just in that space of time
or
Message posted on 25 Mar 2026 04:41 PM
Re: Sky stream
Thank you for the advice,I really appreciate it
Message posted on 28 Aug 2026 03:29 PM
Re: Sky stream
How do I activate my account on sky stream
