Discussion topic: Sky stream volume control stopped working on LG tv?
This message was authored by Buffybeetle This message was authored by: Buffybeetle
I have been happily using my LG Oled55G36 and LG G1 soundbar since October 2023 with the Sky Stream remote.  I used it at lunchtime today and then came back to switch on this evening and the remote will no longer control the volume!
I can see from other similar previous posts that this is a known issue and I have repeatedly tried all the fixes offered, rebooted my stream puck, pressed the 1/3, 7/9 etc, replaced the batteries, etc.  On checking settings and firmware, I just get an N/A for the remote control firmware, is this correct or should it read something else?
This message was authored by Dazzasky This message was authored by: Dazzasky
Re: Sky stream volume control stopped working on LG tv?
The remote is still controlling my LG tv as from this morning so is still working.
Buffybeetle
Thank you for replying that but that isn't much help to me, I know it does not impact everyone, but I was looking for a work around from someone who had this issue and resolved it.
https://www.sky.com/help/articles/remote-control-help-sky-glass
Take a look at this to see if it helps @Buffybeetle
Buffybeetle
I have tried everything suggested by the Sky online help and none of it works., I will have to call them as there does not seem to be any other work around
This message was authored by CinderKona This message was authored by: CinderKona
I have an LG C8 OLED. I found i needed to disconnect my hometheatre, go through all the options until you input your TV model and then finally it connected after about the 4th attempt.
2 hours on a Sunday i'll never get back
Buffybeetle
Thank you! I will give that a try, waiting for a delivery tomorrow so a good time to try it as I am trapped at home.
