Discussion topic: Sky stream unwatchable
This message was authored by: Alan+127
Sky stream pixelation makes it un able to watch , I have 65 meg download. Apple t v  and Amazon stick both work fine . I have tried all the help topics and got in touch with sky , if anything it is getting worse . Paying good money for a service that does not work , not happy.
broad band is through sky
This message was authored by: Ellie_TV
Re: Sky stream unwatchable
Is the 65meg download the speed you're seeing when you run a network test from the get help section of the Netflix app on the puck?
Avatar for Alan+127
Level 2 icon
Yes this is the speed showing on the stream box
every other device  , firestick. Apple TV and smart tv apps all work fine . The problem is with the streaming box
@Alan+127 what did Sky say when you contacted them? It sounds like you'll need to speak to them again. Ask for a replacement Puck. It's unlikely that you'll have the same problem with a replacement. if it's Puck related.
Avatar for Alan+127
Level 2 icon
Hi Spoke with SKY and they are nowgoung to provide me with full Fibre WIFI . I will see if this works but I have my doubts
