Discussion topic: Sky stream remote mixed up buttons
Message posted on 18 May 2025 02:16 AM
I have the sky stream. One minute the remote was fine next thing the buttons are all mixed up, volume no longer works and the search options appears when pressing the volume button. The microphone button doesn't work, number 1 doesn't respond, 2 changes channel. Not sure what has happened. I've reset many times, even did a factory reset of the puck, but no luck. Will I be able to get a free replacement.
Message posted on 18 May 2025 09:06 AM
Re: Sky stream remote mixed up buttons
@Chloe230 wrote:I have the sky stream. One minute the remote was fine next thing the buttons are all mixed up, volume no longer works and the search options appears when pressing the volume button. The microphone button doesn't work, number 1 doesn't respond, 2 changes channel. Not sure what has happened. I've reset many times, even did a factory reset of the puck, but no luck. Will I be able to get a free replacement.
Due to the fact you have reset the remote and it's still not working, I have escalated your post to Sky. Keep an eye out for a message from them. @Chloe230
Message posted on 18 May 2025 09:36 AM
Thanks for escalating. we've sent an invite to @Chloe230.
Tom
Message posted on 18 May 2025 12:22 PM
Check the batteries in case they've leaked. This shoudn't happen, but it's worth ruling it out.
