Discussion topic: Sky stream remote lg tv not communicating
Message posted on 16 Feb 2025 09:34 PM
Hi I have an Lg web os uf850v and have tried to program the stream remote to adjust the volume and put the tv into standby with no luck. However if I connect my soundbar using the optical lead it does adjust the volume. The only trouble is i don't want to use the soundbar any more. Thanks
Message posted on 16 Feb 2025 09:49 PM
Re: Sky stream remote lg tv not communicating
Hi @Davidj5
The best thing to do is reset the remote and go back though settings. Try similar LG TVs. Remember turning off requires a long press of the button.
Sky seem to have had issues with LG and they issued this guide: https://www.sky.com/help/articles/remote-control-help-sky-glass-lg-tv
MikeAlanR
