2
This discussion topic has been answered Discussion topic: Sky stream puks
This message was authored by: Natabox1978
Sky stream puks
How much does it cost for additional puks to use with Sky stream? I already have two.
This message was authored by: Fothergill1 Answer
Re: Sky stream puks
Hi @Natabox1978 Additional pucks cost a one off £39.95 As you must already have a whole home subscription covering the other pucks there will be no further charge.
The pucks are loaned to you and not purchased.
Re: Sky stream puks
Re: Sky stream puks
Any additional Sky Stream pucks cost a one off fee of £39.95.
You can add them from your MySky app or MySky online account, under Your products.
As you mention you have two pucks already, I'm assuming you are already paying for the Whole Home pack that will cover you up to a maximum of six pucks within your household.
