4
This discussion topic has been answered Discussion topic: Sky stream pucks
This message was authored by: BC1956
Sky stream pucks
I have 2 sky stream pucks they do not talk to each other, I cannot resume on one were I left off on the other. They are both on the same wireless set up and Sky router also they are out of sync if I am watching the same channel on both one lags behing the other by about 2 seconds
Sky FF Gigafast / Sky WiFi Max / Sky Stream / 2 Pucks / Sky Ultimate TV / Sky Sports / Sky Cinema / Sky Whole Home / Sky Ad Skipping
This message was authored by: Mister_Dalek Answer
Re: Sky stream pucks
This is normal. The pucks operate entirely independent of each other and don't directly communicate. They are each connected to a Sky server which hosts all the apps, and all information relating to your account. Live channel streams also come direct from these servers and can never be perfectly synchronised due to the variances in network speed and bandwidth.
It can take a little while for viewing information (ie where you are up to in watching a show) to be synchronised on your account so that you can carry on watching something on another device from the same point. There's currently no way to enable a synchronisation to occur as it's partly down to the third party apps.
Avatar for BC1956
Level 5 icon
Thanks for this @Mister_Dalek quick response and informative reply👍...........I recently moved my services to Sky wasn't aware these would be issues, Virgin STB's talked to each other. and were always in sync.
Different technology and topology (despite superficial similarities and an unfortunate naming coincidence)
As @Mister_Dalek indicates, each Sky Stream puck is an independent network client at the subscription address: their only overlap is within Sky server infrastructure.
Avatar for BC1956
Level 5 icon
Thank you for your response
Answered - Go to Answer
