3
This discussion topic has been answered Discussion topic: Sky stream puck
This message was authored by: Samg1
Sky stream puck
Hi. Can I keep a sky stream puck on its side to hide it.
Will it still work?
This message was authored by: GD1 Answer
Re: Sky stream puck
@Samg1  As there is no moving parts inside such as a hard drive it shouldn't affect  the puck being on it's side as long as it has plenty of ventilation
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Re: Sky stream puck
Re: Sky stream puck
@Samg1
Orientation isn't a problem, but anything likely to attenuate WiFi reaching the puck absolutely is (unless it's using ethernet instead)
Avatar for Samg1
Re: Sky stream puck
@TimmyBGood @GD1  Thanks for your help
Answered - Go to Answer
