10
This discussion topic has been answered Discussion topic: Sky stream puck
This message was authored by: Jacob77
Sky stream puck
I've recently bought the sky stream puck along with sky broadband. The puck arrived first and worked for a while 10 minutes before constantly freezing and turning off. I've reset the box 2 times. Done all the steps I've been suggested and nothings working. Can anyone suggest anything or do I need to request a replacement box?
This message was authored by: Angel_Aka Answer
Re: Sky stream puck
Have you checked the speed the puck is receiving? To do this, open the Netflix app, navigate to the get help menu (top left when clicking on your profile) and run the 'check my network' - this will give you an indication of the actual speed reaching your puck.
It needs to be a sustained minimum of 25Mbps for the puck to function with any sort of reliability.
Re: Sky stream puck
Re: Sky stream puck
Hi @Jacob77 and welcome to the forum. Hopefully your new broadband will resolve the issue when it arrives as one of the main reasons for freezing is the quality and speed of the Wi-Fi signal being received at the TV/puck. Note this is not the speed being received at the router.  This can be checked with the Netflix App (Get help > Check network) and is often much less than you might expect. The minimum speeds  recommended by Sky are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
These speeds assume there is nothing else in your home using up your WiFi bandwidth.
If your speed at the TV is borderline try connecting via Ethernet cable. If this is not practical you can use powerline adapters (about £40 at Amazon). Note the Ethernet port on the Glass TV (& pucks) only supports 100mbps so don't waste money on the more expensive 1gb powerline adapters.
Avatar for Jacob77
Re: Sky stream puck
I have done the speed test on Netflix app with my sky puck Ethernet cabled straight into my router and says I'm getting 83mbps. Yet it's still freezing . Less often but still doing it.
Re: Sky stream puck
Is WiFi turned off in the puck's network settings?
Avatar for Jacob77
Re: Sky stream puck
No WiFi is turned on
Re: Sky stream puck
Turn it off then. SkyOS is somewhat random in that it keeps WiFi turned on, even when an ethernet cable is attached, and will try to use WiFi over ethernet so you need to make sure WiFi is OFF in the settings and then restart the puck to make sure it stays off.
Avatar for Jacob77
Re: Sky stream puck
Oh okay thank you I will do that now. Should I reset by pressing the button on the bottom of the puck for 30 seconds till it fully resets?
Re: Sky stream puck
No. Do a restart from the settings menu.
Avatar for Jacob77
Re: Sky stream puck
Thank you. I have turned WiFi off and reset it like you said. Fingers crossed now.
Re: Sky stream puck
Good luck. Hope it improves for you.
