22 May 2023 02:00 PM
Hi
We've just opted for sky stream. Like it, discrete box, but massive plug - wont fit behind TV. Anyone found a sloution to this?
22 May 2023 02:04 PM - last edited: 22 May 2023 02:19 PM
Type A USB to 3.5mm x 1.35mm Barrel Jack cable, plus a slimline USB Type A plug capable of 5V/2.1A
Be advised that using any power supply other than the one provided by Sky is at your own risk, and we'd have to caution against it for pucks on loan rather than purchased (acquired from Sky after February 23rd 2023)
22 May 2023 02:20 PM
Posted by a Superuser, not a Sky employee. Find out more@Ben+m1995 This problem has been discussed before. Have a look at thr following link to see if it gives you any ideas:
https://helpforum.sky.com/t5/Glass-Stream/Alternative-power-supply-for-puck/m-p/3905881#M35678
24 May 2023 06:15 AM
Thanks all. Great support here!
