Discussion topic: Sky stream puck won’t stay in standby and won’t restart with the remote
Message posted on 12 Oct 2024 03:10 PM
Boy am I fed up with Sky Stream - Sky customer for over 20 years - meaning I've spent well over £22,000 with them.... had Sky Stream for less than a week. ... I've spent most of that week following endless routines to fix the problem... but nothing works... each evening when we sit down to watch TV, we have to fish out the puck from behind the tv to turn the bloody thing on, once done the remote works fine... its hard wired to the router via Ethernet, I've changed all the recommended settings.. HDMI, Power Save, remain connected to Ethernet in standby... and, I've followed all of the restart procedures, some of which are ridiculously complicated....
clearly, there is a generic problem with this bit of kit as there are numerous threads all over the internet with thousands experiencing the same challenge...
come on Sky, sort it out, what's the problem and what's the solution.. and, I'm not doing a handstand while hold 1&3 on my remote whilst pressing the puck button with my big toe...😡😡😡😡😡
Message posted on 12 Oct 2024 04:16 PM
Re: Sky stream puck won’t stay in standby and won’t restart with the remote
@Steve2412 wrote:Boy am I fed up with Sky Stream - Sky customer for over 20 years - meaning I've spent well over £22,000 with them.... had Sky Stream for less than a week. ... I've spent most of that week following endless routines to fix the problem... but nothing works... each evening when we sit down to watch TV, we have to fish out the puck from behind the tv to turn the bloody thing on, once done the remote works fine... its hard wired to the router via Ethernet, I've changed all the recommended settings.. HDMI, Power Save, remain connected to Ethernet in standby... and, I've followed all of the restart procedures, some of which are ridiculously complicated....
Hi
seating your puck behind the tv can cause problems...... have you tried with the puck in front of the tv to see if you have the same issues
Message posted on 12 Oct 2024 04:27 PM
@Jporch316 wrote:seating your puck behind the tv can cause problems...... have you tried with the puck in front of the tv to see if you have the same issues
Yes, agree.
Having good broadband is one of the major key factors to Sky Stream.
But, it may also be suffering from interference, the puck much like a Sky Q box can for some customers suffer from this at times. More often seen as an intermittent blip.
Not always a cure, but the following may help to resolve;
Make sure you have a good 6-8 inches free on all sides of the puck.
Do not stack the puck on top of any other device.
Best not to sit it on a glass shelf. Wood is generally the best.
Make sure the puck is in the open, not tucked away in a cabinet or sat directly behind the TV.
Make sure you have no other devices that can cause interference closeby, like cordless phones, radiators, baby monitors, microwaves and the like.
Plus, even though you have mentioned, do make sure you change your puck to the following recommended settings, set in Settings>
Turn wifi OFF under Network (if connected via ethernet).
Set Network standby mode to ON and Overnight power saving is OFF.
Message posted on 13 Oct 2024 01:53 PM
@Jporch316 Appreciate the suggestions, I'll be trying that today... my issue is the TV is wall mounted with nothing below it... so, to have the puck in view will require it to somehow hang below the TV.... not ideal...
is the technology different from that of Sky Q mini boxes as in a previous set-up these were mounted behind the screens without issue....
thanks again
steve
Message posted on 13 Oct 2024 02:26 PM
The stream is connected to the remote via Bluetooth and the tv is connected to the remote via Infra red.
The only way to test if there an issue is to put the stream in front of the tv temporarily and see if it resolves the issue
Message posted on 13 Oct 2024 07:40 PM
Hi
Doesn't that recommendation only have relevance for a wifi connected Puck?
Message posted on 13 Oct 2024 07:54 PM
Hi
Maybe or maybe not ......
Message posted on 14 Oct 2024 08:01 AM
Why would it have any relevance to an Ethernet connected Puck?
Message posted on 14 Oct 2024 08:09 AM
@Exiled-in-HH wrote:Why would it have any relevance to an Ethernet connected Puck?
It's potentially affecting the signal from the remote (Bluetooth) getting to the puck as the remote signal to the tv (infr red) is in front of the puck (including all the interference that brings)
Message posted on 14 Oct 2024 08:10 AM - last edited: 14 Oct 2024 08:11 AM
Do you have a sky device ? If so you could try it on yours ....
Message posted on 14 Oct 2024 08:21 AM
The 3 Pucks I use are all located behind and attached to the TV, and connected to the router using Ethernet😉
There should be NO issue with locating a Puck behind a TV connected to the router using ETHERNET🤔
Message posted on 14 Oct 2024 08:26 AM
It may also be worth trying the puck on WiFi and detaching the Ethernet cable. Some users (including myself) have had a better experience on WiFi than Ethernet.
Message posted on 14 Oct 2024 08:32 AM
Only those with specific ISPs ... Ethernet is best unless the cable is damaged😉
