Discussion topic: Sky stream puck total sound failure
This message was authored by: Anders73
Good evening folks,
My primary puck is periodically experiencing total sound failure.  When this happens I've tried switching channels if watching live TV and flicking between apps but the sound remains dead unless I do a system reset.  This is occurring at least once or twice a day.
Has anyone else experienced this issue and have any ideas for a resolution?
cheers all!
Sky stream #1 - Sony OLED & soundbar
Sky stream #2 - Sony OLED
Re: Sky stream puck total sound failure
I've not experienced this @Anders73
What are your sound settings on Stream currently?
@Anders73  Instead of a system reset if you lose sound go to the setting smenu, Sound & Picture settings, then Sound, select passthrough for example, this should restore sound, then you should be able to set it back to the original settings.
Avatar for Anders73
Level 8 icon
@GD1 I'll try that next time thank you!
Avatar for Anders73
Level 8 icon
Unfortunately that doesn't work when the sound dies, which is at least twice per day.
I'll report to Sky and they can add to their list.
