Discussion topic: Sky stream, puck crashing
Message posted on 26 Sep 2025 01:43 PM
Message posted on 26 Sep 2025 02:13 PM
							Re: Sky stream, puck crashing
Have you checked the speed the puck is getting through Netflix, open Netflix go to help open it and run check my network to see what speed you are getting
Message posted on 26 Sep 2025 02:15 PM
What is your broadband speed to the hub, and the more devices that you have connected to the Internet the weaker the signal is to each one, could be the wifi connection which is not that stable have you tried using an ethernet cable to connect the puck to the hub
Message posted on 26 Sep 2025 02:51 PM
Hi, thank you for your reply, sky puck is connected via ethernet cable, connection speed is 46.18 Mbps
