Discussion topic: Sky stream, puck crashing
This message was authored by: Jacks87
Hi, we have sky broadband and tv and the sky stream puck keeps crashing while watching tv the only solution is to turn off and on at the mains, I have also tried hard and soft reset and consistently refresh the apps but the puck keeps crashing and also freezing. Have checked the speed it's receiving and it's 220 mbps so don't think it's a issue with broadband speed. It happens several times a day. Any help much appreciated.
This message was authored by: peter-marlow+1966
Re: Sky stream, puck crashing
Have you checked  the speed the puck is getting  through Netflix,  open Netflix go to help open it and run  check my network to see what speed  you are getting
P c marlow
What is your broadband speed to the hub, and the more  devices that you have connected to the Internet the weaker the signal is to each one, could be the wifi connection which is not  that stable have you tried using an ethernet cable to connect the puck  to the hub
P c marlow
Avatar for Jacks87
Hi, thank you for your reply, sky puck is connected via ethernet cable, connection speed is 46.18 Mbps
