Discussion topic: Sky stream not showing picture
This message was authored by: Jax501
When I turn on my TV then turn on my Sky stream, it is not turning on, it will go to sky home page I press a channel and will say currently showing, bit the screen is blank, can tou help
This message was authored by: Magthelad
Re: Sky stream not showing picture
Whichever channel I select K get a message,  "Please wait for your programe to load", then, the provrammes menu comes up again!!!
Pretty shabby for £200+ per month!
And all SKY checks show, "OK"!
Firstly, try a restart of the puck.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
Thanks  but nothing's changed.
I think I'll just go back to bed and hooe the fairies come and fix it.
