Discussion topic: Sky stream keeps freezing
This message was authored by: johnharding
Had my sky stream for 5days and it keeps freezing trying to disconnect consistently nothing works
This message was authored by: Jporch316
Re: Sky stream keeps freezing
Hi @johnharding
@first port of call is to check the speed being received by your stream puck .... to do this navigate to the Netflix app - go to settings - network - check network
you need at least minimum 30 mbs to be able to stream.
