Discussion topic: Sky stream box has stopped working it will not switch on
Message posted on 12 Aug 2024 01:47 PM
Sky steam box has stopped working and will not switch on
Message posted on 12 Aug 2024 01:56 PM
Re: Sky stream box has stopped working it will not switch on
@Mattjen wrote:Sky steam box has stopped working and will not switch on
Have you powered it off at the wall for a minute then tried again?
Is there a white light on the front of the puck? It could be the remote is duff - they fail quite often.
Message posted on 12 Aug 2024 02:00 PM
I have powered it off and in a number of times and there is no light on the puck the remote is working as it can still set the volume
Message posted on 12 Aug 2024 02:05 PM
Does it turn on using the button on the bottom of the puck?
Message posted on 12 Aug 2024 02:08 PM
No it doesn't there is nothing
Message posted on 12 Aug 2024 02:21 PM
How long did you unplug it for? Did you try unplugging it for about 10 minutes?
Message posted on 12 Aug 2024 04:56 PM
@Mattjen wrote:No it doesn't there is nothing
It's probably a duff one. Best ring Sky & get a replacement.
