Discussion topic: Sky stream box has stopped working it will not switch on
This message was authored by Mattjen This message was authored by: Mattjen
Sky steam box has stopped working and will not switch on
This message was authored by Mister_Dalek This message was authored by: Mister_Dalek
Re: Sky stream box has stopped working it will not switch on
Have you powered it off at the wall for a minute then tried again?
Is there a white light on the front of the puck? It could be the remote is duff - they fail quite often.
Mattjen
I have powered it off and in a number of times and there is no light on the puck  the remote is working as it can still set the volume
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Does it turn on using the button on the bottom of the puck?
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
Mattjen
No it doesn't  there is nothing
How long did you unplug it for? Did you try unplugging it for about 10 minutes?
NOT a Sky Employee
It's probably a duff one. Best ring Sky & get a replacement.
