3
This discussion topic has been answered Discussion topic: Sky stream at Curry’s
This message was authored by: WelshPaul
Hi, as per the title, can you buy Sky Stream from a local Curry’s store? If so, do they give you the Sky Puck hardware there and then, or is it still delivered via courier?
This message was authored by: Anonymous Answer
Re: Sky stream at Curry’s
@WelshPaul As far as I know you can buy it in store in terms of ordering but the puck is delivered by Sky.
Edit: I've just had a quick video call with Currys and they have confirmed this. You buy your package etc in store but Sky deliver the puck.
@WelshPaul  Curry's only place the order with sky everything else is handled by sky has normal
you won't get anything on the spot
And as an FYI EE are reselling Sky Stream via their website and and app too in a similar deal with Currys.
MikeAlanR
