Discussion topic: Sky stream & slow broadband
Message posted on 02 Mar 2025 12:49 PM
Message posted on 02 Mar 2025 01:07 PM - last edited: 02 Mar 2025 01:09 PM
Re: Sky stream & slow broadband
There's no good solution to bandwidth demand on a poor connection: Stream is going to try to take as much as it needs, and if there isn't sufficient then you're going to have an unhappy experience. In theory you might get away with HD consumption as long as there's no other significant use at the same address, by Sky might well simply refuse to offer the product.
Message posted on 02 Mar 2025 01:35 PM
Message posted on 02 Mar 2025 04:18 PM
I'm using a 5g router from three network.....everything works fine on sky stream....if your in a decent signal area for 5g it might be worth looking into it....
Message posted on 03 Mar 2025 11:59 PM
Thank you for your reply, I'll look into 5g in my area!
Message posted on 04 Mar 2025 09:16 AM
There's also satellite internet options like Star Link from SpaceX... if you can stretch to that and are comfortable supporting the boss of SpaceX.
