Discussion topic: Sky stream Various errors not sure were to start.
This message was authored by: DF19
Had these problems a while may all be interelated
1) Have the stream wired via ethernet direct to hub.  But every morning it comes up and reports no wifi even though wifi is turned off
2) Have also set Network standyby mode to ON and Overnight power saving to Off, was told this last year that it shoudnt go to sleep and remember its settings.
Can you help in anyway to resolve these problems.
Avatar for DF19
Re: Sky stream Various errors not sure were to start.
Sorry various versions are.
Thanks again.
Hi @DF19
I don't have an answer for your actual issue. You've done all of the things I'd usually suggest doing in this situation.
I assume that WiFi isn't a good option for your setup? I know ethernet is better on paper but it might be worth considering just using WiFi. Appreciate that might not be viable though so just putting it out there.
This message was authored by: trevforum
Sometimes if you have "dirty mains power" a mains conditioning, surge protection adapter can help in my experience.
Sky Stream, Sky Glass, Philips 77OLED+950, Pioneer LX-901 7.1.4, EE 900 FTTP
Avatar for DF19
So just an update this morning tried to get to settings, But everytim stopped at first option and locked. pressed home button and started again. woudnt go into mention, Said there was "No options found". Turned on and off still got no furthur.
So to prove if it was a Broadband issue tried on smart tv and up pops BBC no problems. Any idea what to try next "Sky" ?
Thanks so far everyone.
This message was authored by: peter-marlow+1966
I think  you need to contact  sky it may be a faulty  stream  puck, i Don't know  for sure  but i have never come across  this problem
P c marlow
Avatar for DF19
Another small update Just watching Calendar news Good Friday Evening got two minutes in and No picture or sound just a Blue Screen. Instead of Unplugging, Just used System Management "Restart Device" and came back after a few minutes.
Swapped the ethernet cable between the puck and the smart TV, incase there is something the puck doesnt like with that cable. As the Toshiba smart tv works fine.
Thanks for listening.
Avatar for DF19
Any sky employees got a Idea on how to fix this.
@DF19 Sky employees do not provide support in the forum it is a customer-to-customer channel although Sky staff moderate thr forum.
I had a similar issues a few weeks back with one of my pucks which I sorted in the end by rebooting both the puck and the broadband router.
