Discussion topic: Sky stream
Message posted on 24 Apr 2025 02:05 PM
Sky stream
How do stop my stream puck going into standby it seems everytime i turn the tv on i get a screensaver like pic saying " Do you want to turn your set top box on ? Check the connection and cables...
I have a lg tv
Cant find anything in settings to stop this happening, Its every morning mainly
Thanks Gary
Message posted on 24 Apr 2025 02:10 PM
Re: Sky stream
@gazzaman44 wrote:How do stop my stream puck going into standby it seems everytime i turn the tv on i get a screensaver like pic saying " Do you want to turn your set top box on ? Check the connection and cables...
I have a lg tv
Thanks Gary
That's a message from your tv and not Sky Stream. As it says it's telling you your Stream is not on. @gazzaman44 When you turn Stream on then the message will disappear
Message posted on 24 Apr 2025 02:19 PM
Re: Sky stream
Hi thanks for reply @Dazzasky do you know if there is anyway to stop the puck from going into standby especially overnight ?
Message posted on 24 Apr 2025 10:32 PM
Re: Sky stream
Hi @gazzaman44 To stop your puck losing the network connection when it is in standby just go into the Settings > Start up & standby menu and make sure that the option for "Networked standby mode" to ON. I would also turn OFF the overnight power saving at the same time but that is not strictly necessary..
