Discussion topic: Sky stream. Starting a show at x minutes
This message was authored by cashie This message was authored by: cashie
A sports event I was watching finished very late so I decided to watch it the next day, I found it but it was 9 hours long.
I know with Sky+ you had the option of starting x minutes from the start; is there a way on Sky Stream, other than fast-forwarding, of doing the same?
This message was authored by tweetSP0RT This message was authored by: tweetSP0RT
Re: Sky stream. Starting a show at x minutes
Not that I've found. I tend to use the voice control to fast forward X minutes/hours as (when it works!) it is quicker than fast forwarding.
This message was authored by A+JW This message was authored by: A+JW
You can use voice commands for things like this. You can start and then say "Skip 3 hours", or whatever you want to skip.
An ex-Sky Stream customer
cashie
Thanks, I'll give voice control a try.
cashie
I was hoping to be able to watch the final nine holes of the US Open golf but it looks like the live broadcast of the final round is no longer available.  It's there in the menu but saying "finished".  There is a highlights show but that's not what I want.
