Discussion topic: Sky stream. Possible to change HD/UHD format for different TVs?
Message posted on 20 Apr 2024 08:26 AM
I'm sure there's an answer to this but I can't find it. I'm having an issue with UHD content on one TV in my house. I have 3 TVs, 2 UHD and 1 HD only. Each TV has a puck. So for F1 I have it set up on the playlist and it defaults to UHD content which is fine for the UHD TVs. But my hd TV won't play the content and I can't seem to find any way round it or a way of changing it to hd on one TV only. The puck is set to hd content. Is there any way round this or manually changing it on each stream?
Message posted on 20 Apr 2024 09:07 AM
Re: Sky stream. Possible to change HD/UHD format for different TVs?
Can't you create a new HD-only playlist and add content from the HD broadcast streams on the EPG to it? There's no hard drive to fill up so making duplicate playlists in different resolutions is no big deal. If it works of course.
Message posted on 20 Apr 2024 09:08 AM
Tried that. Even though the puck is set to HD. For some reason the new playlist still only contains the UHD content which is a pain
Message posted on 23 Jun 2024 09:45 PM
I am also having this issue. If anyone has an answer that would be really helpful.
