Discussion topic: Sky stream Keep turn self off
This message was authored by: UkzVortex98
My Sky Stream keeps turning itself off when feeling then to of the puk is not even hot but the bottom of the puk is Red hot and Tv stand what is wood is hot where Puk as been what I am think it warming self up on bottom to it temper cut off point then turn it self off does any one from sky or none sky think I am right and got any idie to make air grap under puk cost free but it does not do it all time only when we watch Live Tv 1080p or 4K
Re: Sky stream Keep turn self off
I would contact Sky to arrange a replacement. If it's red hot to the point it's making the surface hot I wouldn't mess around and would just try to replace it.
You can use the Sky Help portal to contact Sky. If you want to speak to somebody, you can click "Need more help?" at the bottom, and within that content you will see a phone number (we can't post phone numbers in this community).
Separately, is the puck in a space that's well ventilated? Eg: it's out in the open and isn't covered up?
Avatar for UkzVortex98
It is replacement one all ready
Did the previous do the same thing?
Can you respond re: the ventilation around the box?
Also, are you confident the wiring/plug socket you're on is okay?
Did the previous do the same thing? Yes, randomly, but I never felt it bottom of it
Can you respond re: the ventilation around the box? there nothing around it open to air
Also, are you confident the wiring/plug socket you're on is okay? cable are all fine
