This discussion topic has been answered Discussion topic: Sky puck with no TV
Message posted on 29 May 2026 08:11 PM
Hi all, I have a laptop (only, no TV) and got the Sky Ultimate package which I received. I downloaded the Skygo app for my laptop which is working (I have the TV channels, Sky channels etc). However, the remote doesn't work with the Sky puck - can I make it work without a TV? I'd like to have access to Disney+, HBO etc.
Thanks!
Message posted on 29 May 2026 08:14 PM
@Dee197 Sky Go the app does not support apps, the remote control is useless on the laptiop.
For full functionality the puck needs to be connected to a TV, using an app on a pc doesn't give you access to the puck.
Message posted on 29 May 2026 08:27 PM
Re: Sky puck with no TV
I thought as much, just wanted to make sure. I have channels now to watch on my laptop which I didn't have before so silver linings and all that jazz...
Thanks!
Message posted on 30 May 2026 08:29 AM - last edited: 30 May 2026 08:39 AM
To link the 'free' apps to your Sky subscription the puck must be used at least once. After that you use the same credentials with downloaded Disney+, HBO Max and Netflix apps on the laptop.
Message posted on 30 May 2026 09:00 AM
@Dee197 wrote:I thought as much, just wanted to make sure. I have channels now to watch on my laptop which I didn't have before so silver linings and all that jazz...
Thanks!
If you're only going to use a laptop then you'd be much better off getting a NOW TV subscription. Particularly if you're not going to activate the Netflix/Disney+ subscriptions. All the same Sky channels are available for a lot less money.
