Discussion topic: Sky puck not reacting
This message was authored by: Cmcc82
Message posted on 12 Nov 2024 09:04 PM
Hi Using a sky stream pick in Ireland. On Saturday light wouldn't come on..replaced batteries in remote even though remote seemed fine and working. Now it happening again. Can't even reste it using the instructions they gave to hold down 4&6 and turn off etc. What to do now if can even reset the puck?
This message was authored by: Jporch316
Find out more
Message posted on 12 Nov 2024 09:11 PM
Re: Sky puck not reacting
Hi @Cmcc82
try this
The remote can be reset and paired again following these steps;
- Press and hold 7 and 9 together on your Sky remote for three seconds.
- Press and hold 4 and 6 together for three seconds.
- Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
if that doesn't work try pulling the plug completely from the wall for a few minutes
