Discussion topic: Sky puck changing channels
This message was authored by: GiorgiGallier
Our sky stream puck keeps randomly changing channels or sometimes it looks like someone is pressing the number buttons and it's turned it's self off once.  Tried resetting it ect..
Re: Sky puck changing channels
Turn it off at the mains for a couple of minutes or complete a reset in the settings manual - see if that helps
If you have already tried restarting,  via a power restart or in settings could be a stuck remote control button.
Remove the batteries from the remote and give each button a good press to loosen.
Put batteries back in and try a re pair of the remote;
  1. Press and hold 7 and 9 together for 3 seconds.
  2. Press and hold 1 and 3 together for 3 seconds.
  3. Wait until you see the 'Your remote is now connected' message and select Continue
Avatar for GiorgiGallier
Nothing helps, we've reset it and restarted it many times, it's ongoing for months now
We've done this many times, it's been going for months
This message was authored by: Nigelb1972
Has anything been spilt on the remote? Something sticky, like pop etc.?
