Discussion topic: Sky glass/ sky puck
This message was authored by: Mickysul
Sky glass/ sky puck
Recently just had sky glass installed and got two sky pucks for other rooms in the house , when first turning them on asked to connect to the WIFI which I done and said was successful , then went to other screens where it tries to download and then comes up with software error and to retry , done this on both and does this to both of them , I have tried doing the reset where you turn off and hold button in til it flashes and does the same thing , I have tried to do this right next to the router in case it was the WiFi strength and did the same
This message was authored by: Dazzasky
Re: Sky glass/ sky puck
I have escalated your post to Sky @Mickysul keep an eye out for a response from them.
I see you have tried the recovery procedure in step 2 of the 'Software error' help article below.
Would suggest trying a forced update as in step 4
https://www.sky.com/help/articles/sky-glass-software-error-sky-stream
This message was authored by: Mr+Flibbles+86
Thanks for escalating this. We’ve sent an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
