Discussion topic: Sky Streaming Puk slow and unresponsive
This message was authored by: Jsljsl
Does anyone else find the Sky Streaming Puk slow and unresponsive..... coincidentally (?) even more so whenever I turn down full fibre?
And options such as 'watch from start' often drop out?
This message was authored by: Stephen+Mourton
Re: Sky Streaming Puk slow and unresponsive
@Jsljsl  It is difficult to be certain but usually there are two reasons this can happen.  Firstly check your broadband speed, you can do this in the Netflix app whether or not you have an account, just go to the help page and you will see the option to check your broadband speed.
The other reason can be where your puck is.  It needs to stand alone with nothing touching it and about 6 inches of clear space around it.
Let us know if either helps!
Avatar for Jsljsl
Hi, cheers ...the puk is on a patio door step,  which is under the sky dish and the broadband booster (also useless) is about 6" away, then the router, and that all.
The TV is about 4-5 ft away from them
@Jsljsl
It's not ideal to have any wireless devices that close to a 'booster'.  Obviously a Sky dish location makes no difference at all to Stream.
@Jsljsl I would guarantee your setup is completely at fault and not the puck
Just from the way you described it there
The boosters are fantastic when set up correctly
Avatar for Jsljsl
Ok, thanks....I'll move it over and see if that helps
Avatar for Jsljsl
Other than plug it in, what exactly is the set up then please?
