11 Oct 2023 06:36 PM
Hi there
I've just switched from Sky Q to Sky Stream. I need to enter an email address and password for one of my apps and have absolutely no idea how to enter the letters for this from my remote.
My Sky Q remote had letters assigned under each number on the keypad and this seems to have disappeared on the Stream remote.
I have paired the remote using the 7+9, 4+6 and 3+1 command and the settings are in. I've tried pressing every button but nada. I also can't seem to access the Options menu - it only gives me a Search function?
Can anyone tell me how to access this? Otherwise I can't access my app!
Heather
11 Oct 2023 06:45 PM
Posted by a Superuser, not a Sky employee. Find out moreWhen you click on the username / password part you should get an on screen keyboard
12 Oct 2023 02:57 PM
Nothing happens. The username/password field comes up and my remote doesn't do anything. Have tried every number and button ...
12 Oct 2023 03:33 PM
Try repairing the remote as below
The remote can be reset and paired again following these steps;
12 Oct 2023 08:59 PM
I tried that too and went through all the settings for sound, tv, etc and still no letter keypad.
12 Oct 2023 09:32 PM
Posted by a Superuser, not a Sky employee. Find out moreCan you take a screenshot please 🙏
