Discussion topic: Sky Stream puck won't power on from standby
Message posted on 30 Jan 2025 08:36 PM
Message posted on 30 Jan 2025 08:57 PM
Re: Sky Stream puck won't power on from standby
Hi @GaryS77 you have already done all the obvious troubleshooting procedures to resolve it so I will escalate your post to the Community Messaging Team for some online chat. I suspect they will want you to do some of the procedures again but it is possible your puck is faulty so if they can't help suggest they replace it for you.
The link below explains how the procedure works
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Keep a look out for the speech chat bubble that will appear on the bottom left of your screen when you are logged onto this forum (you will need to refresh your browser from time to time until you see the chat bubble). When the blue bubble does appear you have 48 hours to respond or the chat will be automatically closed. Note replies from Sky are not instant so you will need to regularly check the chat thread.
Message posted on 31 Jan 2025 02:36 PM
Thanks for escalating. We've sent an invite to @GaryS77.
Tom
Message posted on 01 Feb 2025 10:37 AM
Much obliged. Problem suspected to be the remote so a new one has been ordered - hopefully that will fix the problem.
