Discussion topic: Sky Pucks not holding power
Message posted on 01 Feb 2025 09:51 AM
Hi all
got two sky pucks, only been used for a month before cancelled sky. ended up buying the pucks as forgot to send them back.
got sky back earlier this week and the pucks will not stay on power wise. any ideas ? one worked for a day then wont turn on
both pucks iluminate when plugged in, but go off shortly after and wont come back on
many thanks
Craig
Message posted on 01 Feb 2025 10:33 AM
Re: Sky Pucks not holding power
Probably unrelated to the issue, but paying a non-return fee isn't purchasing the hardware.
Message posted on 01 Feb 2025 12:26 PM
They might be stuck in a semi standby mode or just need a forced reset.
Try doing the recovery procedure as described in step four here;
https://helpforum.sky.com/t5/Sky-Stream/Sky-Pucks-not-holding-power/td-p/4898925
