11
This discussion topic has been answered Discussion topic: Sky Stream is useless
This message was authored by: JonSher81
I'm 2 months into contract and I've had nothing but issues! The router is one end of the livingroom and the puck is the other end! Technician wanted to throw cables over my roof and down the back of the house and drill into the wall. I didn't want all that, so the puck is now working off the WiFi without an ethernet cable! It's absolutely useless!. It's impossible to watch live TV without the picture freezing and lagging! When I try get assistance off Sky I'm told buy a WiFi booster or contact here for support!
This message was authored by: MarkGoldsmith Answer
Re: Sky Stream is useless
@JonSher81 wrote:
I can't use ethernet cable as the TV is mounted on the wall one end of the room, and the router the other end of the room. 1) there wouldn't be a cable long enough. 2) I dont want a cable running along my floor and and up the wall to the TV. There is literally the length of the house between TV and router
The other option is a powerline adapter, which would negate requiring a long ethernet cable running the length of the house.
How long is the living room?
Check what speed your Puck is receiving within the Netflix App on the Puck.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
@JonSher81
While you aren't obliged to accept unreasonable options, it's probably important to understand that there are only a limited number of remedies which Sky can offer: unlike with Sky Q they don't loan wireless boosters for Stream.  Ultimately they can just release you from the rest of the contract and leave you to find another way to watch television.
Avatar for JonSher81
I wish they would release me!
Just a standard size sitting room I'd say! Fireplace in the centre of the room and the TV mounted on wall to the left of the fireplace, and router sitting on a shelf to the right of the fireplace.
I just checked network speed via netflix, 3.92Mbps🫣
This message was authored by: Hunter2660
Which is your problem, the puck isn't getting a good enough signal. Sky recommend 25mbps, 30mbps for UHD.
There's definitely a cable long enough.
I'm on my to get one now actually. Thanks
This message was authored by: 2muchTV
Powerline plugs can be very useful, but note that each plug ideally should be on the same electrical circuit e.g. I cannot use them on different floors in my home.
They work well for me for extending signal into my garage and garden as well as a camera in my pond.
Former Sky HD+, Q and Stream customer
Now TV Sports + Entertainment + Cinema + Ultra Boost @ £33 pm
Digi £15 pm 900/900
3 x Asus XT9 mesh & 2 x Asus RT-AC58U
65" Samsung S92C OLED TV
6 other streaming TVs
I bought some this morning and it worked a treat. Went from getting 9 Mbps to getting 89Mbps
