3
This discussion topic has been answered Discussion topic: Sky Stream and Sky Devaliet Sound System help required
This message was authored by: Reden
Good evening everyone. I have recently acquired the new Sky Stream system. In one room I have connected the Sky Stream Puck via the Sky Devaliet Sound System. The sound plays through the sound box perfectly but I have one problem. When the system is put in shut down/ standby mode and I press the Home Button on the Sky Puck Remote, the Sky stream system will not start up until I turn it all off and on at the wall. If anyone can offer any advice it would gratefully recieved, thanks in advance.
Avatar for Reden
Level 2 icon
This message was authored by: Reden Answer
Re: Sky Stream and Sky Devaliet Sound System help required
Avatar for Reden
Level 2 icon
Soultion in case anyone has a similar problem...https://www.sky.com/help/articles/setting-up-sky-soundbox-sky-stream-puck
@Reden
Perhaps also worth noting that the Sky Soundbox was a 2017 product intended specifically to work with Sky Q, and both are hardware which pre-date the acquisition of Sky Group by the Comcast Corporation.  Comcast took over in late 2018 when the Soundbox had already ended its single production run and largely disappeared from sale, and the puck doesn't appear until October 2021.
Avatar for Reden
Level 2 icon
Thanks for the helpful comment, I assume I need a new soundbar for it work seamlessly with the streaming puck...👍🏻
Answered - Go to Answer
