Discussion topic: Sky Stream and Galaxy Frame TV
Message posted on 17 Aug 2025 05:53 PM
Has anyone experienced Stream on Samsung Frame TV? Can one switch seamlessly between Art and Sky without touching Samsung's notorious AD ridden UI?
C
Message posted on 17 Aug 2025 06:05 PM
Re: Sky Stream and Galaxy Frame TV
@bazjoyce Stream remotes are only designed to control the TV Volume and on/off function, anything else you need on the TV will need the TV remote.
Message posted on 18 Aug 2025 07:09 AM
If it has modern hdmi controls then simply pressing the "sky" button on the stream remote should initiate the hdmi handshake, wake the stream puck and switch the tv to the the hdmi input .......
I've no experience of the frame though so not sure if the art is just a screensaver or a UI app ?
