06 Mar 2023 11:12 AM
I've noticed recently (since latest update) that when I use the "Watch from the start" feature on live tv, the fast forward doesnt work well anymore, I used to be able to go straight to x30 fast forward and it would work fine, now it sometime works or it just pausing, flicking through to x6 or x12 etc back and forth until one of them works.
Anyone else have this issue or just me, used to work fine up until recently.
06 Mar 2023 12:11 PM
Same here too, I thought it was just me. Sometimes the playlist doesn't update either for live sports to rewatch
06 Mar 2023 12:22 PM
Yep I'm experiencing this issue has well. It's very buggy. Hopefully picked up on the next release, we hope!
06 Mar 2023 12:26 PM
Fast forward and rewind has never worked well on any content from Sky channels for me. Documentaries, Sky Atlantic, Sky Max, etc - all are impossible to skip through without having to revert to the flaky voice control which maybe works 50% of the time. Not good enough.
06 Mar 2023 12:32 PM
Definitely not good enough, especially since the latest update too
06 Mar 2023 12:34 PM
Glad it isnt just me then, the problem yesterday was watching for example ITV "Watch from the start" , so it wasnt playing back from the ITVX player (that's a whole other story), I guess it was playing back from Sky's cloud recording.
Like i said it's been all fine up until the last update .
06 Mar 2023 12:43 PM
I've noticed it says waiting for your programme to start especially on live TV or there is a technical fault. So it can be very annoying and it means rebooting the puck
16 Mar 2023 01:36 AM
I'm not even getting the option to watch from the start usually. The bad system becomes worse!
20 Mar 2023 09:44 PM
This has become almost unusable now. Especially Channel 4 programmes.
the fast forward option just doesn't do anything and I'm finding I can only skip forward minute by minute.
21 Mar 2023 09:58 AM
Yes, it's been rubbish for a number of week now, it's very frustrating to use at the moment, I assume Sky are aware of this?
21 Mar 2023 10:24 AM
Posted by a Superuser, not a Sky employee. Find out moreHi @TechMaster
Have you contacted Sky to report the issue?
Thanks,
Tim
21 Mar 2023 10:30 AM
No, is there an easy way to doing that? I thought you just had to post here and hope for the best
21 Mar 2023 10:31 AM - last edited: 21 Mar 2023 10:34 AM
This is a customer to customer forum where we just help out. But I can escalate your post to Sky which means they will contact you via chat to troubleshoot.
The link below explains the escalation process.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Thanks,
Tim
21 Mar 2023 10:44 AM
Sometimes it can skip forward to live when it's been paused for a bit which can be annoying if you miss an important moment
21 Mar 2023 10:51 AM
Just to clarify to avoid any confusion/mixed messages, my issue is with the "watch from the start" feature, not fast forwarding via catchup apps like ITVX etc
Trying to fast forward x2, x6, x12 or x30 is hit and miss, sometimes nothing happens sometime only x6 works sometimes only x30 works, sometimes nothing works but continually flicking between x2,x6,x12,x30 eventually one of them will work.
I don't recall having this issue before the latest firmware update., i assume I am not the only person having this problem so will try and report it as discussed above
