Discussion topic: Sky Stream Success from Sky Q
Message posted on 13 Jun 2025 01:46 PM
I have been using Sky for 25 years plus and had all version of Sky you can purchase.
Recently I changed from Sky Q and a mini box to Sky Stream with two pucks.
The change over was pain free and the picture of the puck is better than Sky Q mini box which is expected as it is UHD.
With experience of Sky over many years, WIFI is not used, Internet is cable direct to the units over power lines, I had no problems at all with the process of changing over or picture drop outs . Following the install guide and then alter the settings to give max picture quality, sound and removed any power saving settings first thing to do.
I miss the recording of Sky Q and the all the extra channels but I am getting used to the reduced number of channels.
Sky Stream is different, cheaper and better quality picture and no dish, would I recommend YES.
Message posted on 13 Jun 2025 11:05 PM
Re: Sky Stream Success from Sky Q
I moved from Sky Q 3 years ago. Initially I had the Glass TV as at that time pucks were not available on their own. I later changed to a stream puck and fully agree that the picture quality from the puck when attached to a decent TV is outstanding.
The streaming platform is not without its faults but it suits me and like you I am perfectly happy with it. I didn't really miss the recording option of Q as I personally find the playlist far more convenient.
When I had a serious puck issue a few weeks ago the Customer Service team were quick to identify that my puck had failed and immediately sent me a replacement.
