Discussion topic: Sky Stream Sound
This message was authored by: JackSparrow2
Sky Stream Sound
When connected through Ethernet my sound for my sky tv keeps cutting out frequently. I have had a hard reset of the puck but still not difference.
This message was authored by: Jporch316
Re: Sky Stream Sound
If it not happening via wifi then it maybe worth trying a different ethernet cable
also try changing the sound setup in the sound settings to auto or pcm
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Avatar for JackSparrow2
Thanks, changed my Ethernet & used WiFi again. On the TV wifi/ethernet jumps but when use the different apps for tv it doesn't jump.
Ethernet not obtaining IP
My Ethernet is not obtaining an IP address when I try to reconnect sky box.
Re: Ethernet not obtaining IP
Are you using a network switch ?
What is a network switch?
You plug it into your router via ethernet and it gives you a load more ethernet ports .... I'm guessing not !
Did you try switching the sound settings ?
also have you tried a different Ethernet cable ?
It is straight into the router.
This message was authored by: littlelol07
I'm having same issues. Connected straight to router by Ethernet. Keeps stopping/ freezing and then returns with sound massively out of sync. Have restarted, unplugged, changed sound settings on puck and tv. Getting to end of tether now. Would like to go back to sky Q if I'm honest
Would be helpful if when your rang them you could speak to someone wouldn't it.
