Discussion topic: Sky puck won’t connect to wifi
This message was authored by: AJ2550
Sky stream won't work on tv, doesn't pick up connection to WiFi or load on hdmi channel.
Re: Sky puck won’t connect to wifi
@AJ2550 if the puck will not outputting even an blue error screen and it is not an issue with the mains power or selection of the correct TV input then the unit is faulty and needs replacing so give Sky a call.
