This discussion topic has been answered Discussion topic: Sky stream - picture stuttering/frame drops
Message posted on 29 Jun 2026 10:42 AM
Re: Sky stream - picture stuttering/frame drops
It is literally in the same room and has worked without this issue for months. 270Mb on Netflix
Message posted on 29 Jun 2026 10:46 AM
@rossc1989 wrote:It is literally in the same room and has worked without this issue for months. 270Mb on Netflix
Great. That's absolutely more than enough for the puck to work with. Shame it doesn't though. I've no idea what else to suggest - it seems to be a Sky issue which one can only hope is on the list of things for them to sort out.
These kind of frustrations are why I ditched Sky Stream and switched to using NOW TV for Sky content. I've had zero issues with it.
Message posted on 29 Jun 2026 07:02 PM
Re: Sky Stream Jittery
Hi,
Sky OS 1.3
Build version QS040.029.00P
UI Version 3.235.0
Platform Version 8.4p29s2
Hardware Model IP061-ef
I'm still getting the odd glitch this evening, but nowhere near as regularly as yesterday
Message posted on 29 Jun 2026 07:18 PM
Notice from your first post, you mention the puck you are having issues with is connected by ethernet.
Your other pucks from what yiu say working are on wifi.
For your Ethernet connected puck, have you turned off wifi in the puck settings, if not it will drop to wifi occasionally and cause intermittent issues.
If you have already done this, we can escalate to the Sky community team to work through the issue with you.
Message posted on 29 Jun 2026 07:37 PM
I've been having similar issues for the past few weeks. Seems to be doing it on most channels. Doesn't matter if it's sport or a movie. Just momentarily pauses. WiFi connection is excellent and good speed shown on Netflix. I've also restarted hub and puck with no improvement
Message posted on 29 Jun 2026 07:54 PM
Same here! It's appearing every 90 seconds or so.
Message posted on 29 Jun 2026 09:19 PM
I'm pretty sure it was off yesterday. Currently watching House of the Dragon, so I'll make sure it's off tomorrow and report back.
Message posted on 29 Jun 2026 09:27 PM
I've switched my picture settings to 1080p HD to see if that improves. House of dragons was jumping around earlier today as was From. Doesn't seem to care which channel or program I watch I get the issue
Message posted on 29 Jun 2026 09:58 PM
I am having the same issue. I have tried rebooting puck and router - no improvement. Stutter/freeze happening on 'live' TV and every app. Have starting using Firestick for Prime, Netflix, iPlayer etc and no issues whatsoever. TV has Freeview fortunately so can use it for live TV. Don't really see the, point in the puck tbh if it's this unreliable.
Message posted on 29 Jun 2026 10:28 PM
Hi,
The wifi is off. I've just watched House of the Dragon on demand. It wasn't too bad but was still present. The jitters were several minutes apart and only minor. I've just put BBC 1 on for the football, and it's pretty horrendous. Every minute or so and a much more substantial jitter. Sky need to sort this out, I won't be paying the best part of £2.5k for this rubbish for the next 2 years.
My streaming apps are fine. It's just affecting live television channels. Initially it was only BBC and ITV but it has started spreading to the Sky channels now.
I did try starting a web chat with a Sky representative it they failed to get back to me.
I imagine that if I were to call Sky they would just tell me to do everything I've already done, like restart the puck and the router. I have 500meg down so that should be more than plenty.
Message posted on 29 Jun 2026 10:36 PM
Exactly the same issue here too.
90mbps in Netflix speed check.
posted on here last week about glitching every 10 - 15 seconds, especially awful during World Cup games. Funnily only became noticeable since World Cup started. Tried all the reboots. All apps for me are fine so have been watching games on them which is a bit of a joke really considering we're all paying for the tv service.
if anyone finds a fix or Sky manages to help resolve it please post in here so we can all move on with our lives!
Message posted on 29 Jun 2026 10:48 PM
Similar issue here too on my puck. Only seems to be with live tv, apps run fine. Currently watching World Cup on bbc IPlayer in uhd with no glitches.
i have 89mbps speed check on Netflix. Hard wired Ethernet connection.
done all the resets/reboots after reaching out to Sky and got nowhere fast.
sky clearly have a big issue here that they need to sort fast.
Message posted on 30 Jun 2026 12:03 PM
Exactly the same here. Started in the last week.
running QSE040 over WiFi with Netflix showing 225mbps. Tried multiple remotes but not resolved.
Message posted on 30 Jun 2026 03:02 PM
No acknowledgment of an issue. I have been messaging for days for a solution.
Nothing has worked.
I sent some pics of the set up a few days ago had some empty boxes and vase in between router and pick.
Got asked last night to remove them so I did, no change.
Today, I have been asked for a picture to prove it. Unbelievable, I did notice that request had no name left at the end of it.
Sky, it's clear we are all having the same issue. It's not our set up or our broadband connection.
