368
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky stream - picture stuttering/frame drops
This message was authored by: SkyStreamWilts
Hi.
I have Sky Stream and Sky Broadband. Up until  few days ago everything was working mostly fine. But just recently I've noticed the normal TV channels are stuttering every so often/dropping frames. It's not all the time, but when it does happen it's very noticeable. It seems to be most noticeable on BBC channels and ITV.
The puck is connected via Ethernet. I have tried resetting the puck and router several times but it doesn't make any difference.
Watching content on streaming apps such as Prime or Netflix doesn't have this problem.
Any ideas/help to resolve this would be greatly appreciated.
This message was authored by: KevNewMedia Answer
Re: Sky stream - picture stuttering/frame drops
Posted by a Sky employee
Hi Everyone,
Thank you again to everyone who has reported this issue and shared their experiences.
We're pleased to let you know that the rollback has now started, and some customers have already noticed the change taking effect. As this is being rolled out in stages, it will continue over the next few days until all affected customers have been updated.
We appreciate that this has taken longer than expected, and we'd like to thank you for your patience while our teams worked to identify and implement a solution.
I'll continue to use this post as the main update point, so please keep an eye here for any further news.
Thank you for your continued patience and for taking the time to report the issue.
Kev
Community Manager
Locked
This message was authored by: SuperMatt
Morning, @SkyStreamWilts. I'll send you an invite to a private chat shortly and we can help you get this working for you.
Just look out for the colourful bubble to start the conversation. Please be aware conversations automatically close if there is no response within 48 hours. Here's more information on how Community Messaging works - https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147#M141
This message was authored by: matt77303
Ive noticed the same over the last week
ive reset router, reset tv settings, factory reset puck.
Connected via ethernet.
Its subtle but reallt annoying.
Matt
This message was authored by: joeabbott
We are also experiencing this issue.
Any luck of a fix?
This message was authored by: N_chill
ive noticed its been worse today, its almost exactly every  12 seconds.
ive done everything i can think of, factory reset tv, reset router, reset ONT box, reset sky puck.
Internet is 500MB + download and its not done this for 7 months,  started maybe 2 weeks ago.
Intrestingly if i pull the power on the puck for a minute or 2 when plugged back in it doesnt do it for a couple of hours then it starts again.
Also doesnt do it when watching netflix on the puck.
Matt
sorry , i didnt get a notification of a reply.
Matt
This message was authored by: Kev1980
I posted a 2 second freeze earlier and no response same issue as raised here.
Any help would be fully appreciated
Avatar for SkyStreamWilts
It was doing it on Sky Arts last night when I was watching the Isle of Wight festival.
Come on, Sky. It's clearly a problem at your end. Sort it out please
I am using wifi and the speed is over 300 mbps and it only started over the last couple of weeks.
watching Belgium v Iran and had 3 freezes in 10 mins
It's possible that these are caused by general congestion on the Sky server your pucks are connected to.
The large increase in numbers of people watching live sport over the summer and the increased heat in recent days won't be easy on the servers having to process all this data and send it out to every Sky Stream/Glass customer.
If this is the cause, then there's not a lot you can do about it. If using a third party app on your puck then try using it on a different streaming device or your smart TV. These devices normally have the app downloaded onto the device itself, not hosted on a server, so there's less pressure on the data throughput.
This message was authored by: Nigelb1972
@matt77303 have you turned off the WiFi? As it's possible that it's still trying to connect via WiFi as it's preferred connection method if you haven't.
This message was authored by: purpleparrotuk
Are you on Q38 firmware?
Mine is QS037.058.00P
We are on QS040.
I don't accept that Sky did not plan ahead for the increased bandwidth over the WC - its a paid (expensive!) service so you should expect a certain level of consistency.
It seems to be since they have introduced the reduced latency 'real-time (RT)' channels (920-949) that the quality of standard channels has dropped.
It's some sort of encoding issue on their end or a dodgy update. Anyone else worked it out?
Locked
