209
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Stream - Hyperoptic Broadband issues
Locked
This message was authored by: Cosypowell
Re: Sky stream not working on multiple pucks
Yeah mine was same until hypoptic did something at there end, its been ok for now but we will see🤔🤔🤔
This message was authored by: Gordon_Hunter
Also ok until I changed channel, shocking service.
Have u tried ringing hyperoptic up, they kno theres a issue with sky glass and sky do too, i did notice when i had issues that Netflix would work, its a strange thing, mine is working great ( at the min )
Thanks, I logged a fault ticket but it has been ignored. I will try calling them.
This message was authored by: CarlW59
Couldn't get Sky channels last night but could watch Netflix, all streaming services worked (Netflix, iPlayer, etc.) except Sky. Had a new puck delivered yesterday and I cannot get it to connect to Sky to initialize, I've reset it but it won't get past 'Upadating software...'
And it's not a speed issue, I've got 480Mbps down and 540Mbps up, it's got to be some kind of DNS issue as it appears in cannot connect to the Sky servers but it can connect to the other services.
I rang them and spoken to them directly, hope u get it sorted
It is a dns problem, i spoke to them and then changed some dns settings at there end and works now, they know about the sky problems, give them a ring like i did only took 5 mins and all ip and running
This message was authored by: Rachmosh112
Re: There is a technical fault with this programme. Please try again later.
Such a frustrating issue, haven't been able to watch TV since yesterday
my internet is with HyperOptic snd get 300 download
This message was authored by: Robert0072
I am also Hyperoptic 1Gb
What router do you have?
I have the Nokia HA-140W-B, with a Nokia HA020W-B extender in another room.
This message was authored by: DEAG60
Fixed mine by changing DNS settings in the router to Cloudflare dns 1.1.1.1
Oh thanks good hopenits all working now
Locked
Answered - Go to Answer
