Discussion topic: Sky Stream Aspect Ratio
Message posted on ‎13 Aug 2024 10:35 AM
Sky Stream doesn't seem to be in wide-screen just 4:3 anyone else having this issue??
Message posted on ‎13 Aug 2024 10:49 AM
Re: Sky Stream Aspect Ratio
@Pumkin007 wrote:Sky Stream doesn't seem to be in wide-screen just 4:3 anyone else having this issue??
What channel are you watching? Have you changed the aspect ratio on your TV settings by mistake?
Message posted on ‎13 Oct 2024 09:03 AM
I've just changed from Sky Q to Sky Stream and I have the same issue with Gold. Sky Q was always in the correct aspect, but nothing seems to make a difference with Sky Stream. Despite being told Sky Stream was a step forward with the latest technology, I'm having my doubts.
Message posted on ‎13 Oct 2024 09:07 AM
@martinlong1965 If the program on Gold is 4:3 then it's being disolayed correctly and not being artificially stretched to fill the screen.
There is nthing wrong with the ouck and it is not a step backwards as your seeing the correct apsect ratio.
PS any black bars you see are actually put there by the broadcaster.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Message posted on ‎13 Oct 2024 09:35 AM
Which ratio do you consider to be 'correct': broadcast or display?
